 Post subject: Recovery engineer is looking work
PostPosted: February 1st, 2023, 3:10
Greetings
I am an experienced engineer with five years of experience in data recovery. I have vast experience in laptop, PC and GPU repair of any complexity, including soldering BGA chips and replacement of block of magnetic heads.
• data recovery from Hdd SDD flash drive,
• work on PC-3000 Flash and PC-3000 UDMA,
• block of magnetic heads replacement,
• laptop and PC repair of any complexity (also iMac repair),
• soldering of any complexity (also soldering BGA chips),
• GPU repair, replacement and soldering,
• motherboards repair (Replacing firmware, soldering),
• repair of the damaged laptop case,
• repair of monitors,
• repair game console
If you are interested write me a pm thank you for your time
 Post subject: Re: Recovery engineer is looking work
PostPosted: July 17th, 2023, 12:12
yurinec wrote:
Greetings
With just one post I don't think you will be able to get PMs.
You might want to post some kind of contact details.
PostPosted: January 16th, 2024, 16:34
Where are you currently located?
I'm looking for a sub-contract data recovery professional in Vancouver.
Frank
