Discussions related to DFL tools: general chat, firmware requests
TRACK SPLIT
May 8th, 2013, 13:19
please
in this situation we need donor ?
Re: TRACK SPLIT
May 8th, 2013, 16:15
yes, u need it
Re: TRACK SPLIT
May 8th, 2013, 23:04
Hello Salim, as for your cases, you must let us know whether you want to refurbish the hdd or recover data from it?
You can consider change totally the firmware and ROM from the same family, you can check your PCB number and write common fw and ROM and then run selftest for hdd refurbishing.
For data recovery, you can try hot swap and see and manage to regenerate the key data modules as suggested in the DFL forum.
Re: TRACK SPLIT
September 10th, 2013, 3:45
YES SALIM
IF MOST OF FW M MODULES ARE BAD YOU SHOULD USE NEW FW OR REFURBISHING FW FILES TO SOLVE YOUR PROBLEM
OTHERWISE Y WASTE YOUR TIME
WWW.WDREPAIR.COM
