 Post subject: Firmware problem with WD20EARS
PostPosted: October 15th, 2013, 14:29
i have a WD My book, that had defective headstack. That was fixed and now i have firmware problems on MOD 0033 and 0031 from P-list
I readed that if i cannot access to p-list MOD the data cannot be recoverable. is that true?
 Post subject: Re: Firmware problem with WD20EARS
PostPosted: October 15th, 2013, 14:53
yes it is true
PostPosted: October 15th, 2013, 16:05
Theoretically, yes, but there are potentially some ways to work with what you have, even damaged. From your explanation, it is not clear if those ways were already pursued or not. If they were not, then can't quite be officially deemed unrecoverable, I think...
PostPosted: October 28th, 2013, 5:11
upload donor 33 and 31 module and after upload clear these modules . and after that rebuil pilst from ss log .
PostPosted: January 13th, 2014, 17:07
Thanks for the help :D
Unfortunately i have HD Doctor for WD and would be perfect if i had that option.
But well anyways, i will keep trying
PostPosted: January 21st, 2014, 3:26
Check for Defects list management. you will see P-List Regenerate. that would be the issue you are looking for. Also Translator Regeneration
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: January 30th, 2014, 12:41
Thanks for the help spildit and shahij
