| Firmware problem with WD20EARS http://forum.hddguru.com/viewtopic.php?f=24&t=27072 |
Page 1 of 1 |
| Author: | gacpac [ October 15th, 2013, 14:29 ] |
| Post subject: | Firmware problem with WD20EARS |
i have a WD My book, that had defective headstack. That was fixed and now i have firmware problems on MOD 0033 and 0031 from P-list I readed that if i cannot access to p-list MOD the data cannot be recoverable. is that true? |
| Author: | waqas_ali766 [ October 15th, 2013, 14:53 ] |
| Post subject: | Re: Firmware problem with WD20EARS |
yes it is true |
| Author: | labtech [ October 15th, 2013, 16:05 ] |
Theoretically, yes, but there are potentially some ways to work with what you have, even damaged. From your explanation, it is not clear if those ways were already pursued or not. If they were not, then can't quite be officially deemed unrecoverable, I think... |
| Author: | waqas_ali766 [ October 28th, 2013, 5:11 ] |
upload donor 33 and 31 module and after upload clear these modules . and after that rebuil pilst from ss log . Thanks |
| Author: | gacpac [ January 13th, 2014, 17:07 ] |
Thanks for the help Unfortunately i have HD Doctor for WD and would be perfect if i had that option. But well anyways, i will keep trying |
| Author: | shahij [ January 21st, 2014, 3:26 ] |
Check for Defects list management. you will see P-List Regenerate. that would be the issue you are looking for. Also Translator Regeneration |
| Author: | gacpac [ January 30th, 2014, 12:41 ] |
Thanks for the help spildit and shahij |
