USB 3 to SATA
Posted: September 5th, 2014, 5:51
by S.K.
Please suggest SATA pcb for 771961. I tried with 771959 , but it does not work with WD tool to repair FW.This can help to connect only to connect the drive with computer sata port and power supply is given only through USB port.
So please suggest SATA PCB which can be used to repair FW on WD fw repair tool.
Thanx
Re: USB 3 to SATA
Posted: October 6th, 2014, 19:35
by data-medics
Do you even have a way to read the ROM from the USB version? Or are you physically transferring it?
