 Post subject: Dolphin Head and Platter Swap and Clean Suite.Pro
PostPosted: April 17th, 2024, 16:03
Hi
I am building a laminar chamber, I have a question: is it worth investing in this set? or look for elements separately?
https://www.dolphindatalab.com/product/ ... suite-pro/
 Post subject: Re: Dolphin Head and Platter Swap and Clean Suite.Pro
PostPosted: April 17th, 2024, 16:24
Where are you going to find "Elastic Band Pro" or "Soldering wire pro" or "Double-sided adhesive pro" or "dust remover pro" or "Clean finger gloves pro" or "Medical cotton pro" or "Clean cloth pro"?
And do you really need this?
Ear Magnifier Pro is used to watch the heads health information and find out which head has white magnetic powder and then see which surface is damaged.
PostPosted: April 19th, 2024, 2:44
what does this
Elastic Band Pro 2
Elastic Band Pro is used to adjust the WD hdd motor balance with other tools.
and this
Soldering wire pro 1
Soldering wire pro is used to adjust the hdd motor balance with other tools.
mean?
