 Post subject: Imaging Hard Drives with USB Interface
PostPosted: October 26th, 2013, 21:36
hi,
i have WD Passport in which drive has usb onboard. it is known that it uses usb-sata bridge chip to encrypt data in real time. how to do data recovery with sata imager.
 Post subject: Re: Imaging Hard Drives with USB Interface
PostPosted: October 27th, 2013, 4:31
Convert drive to SATA.
But then you'll have an encrypted clone, so you'll have to decrypt it.
PostPosted: October 27th, 2013, 10:35
Thanks for your advice. And how to decrypt an encrypted clone.
PostPosted: November 2nd, 2013, 20:46
Convert drive from usb to SATA is easy
but as your drive is encrypt data on the fly its going to be hard.
as your going to need to bypass this
which is a kept secret
good luck
PostPosted: November 4th, 2013, 0:24
good luck
Has been mentioned a couple of times here on the forum.
Users browsing this forum: No registered users and 66 guests
