 Post subject: seagate: 0 capacity
PostPosted: November 14th, 2013, 9:57
I have Seagate barracuda 7200.12 model: ST3500418AS. I connect to PC. It recognizes as 0 capacity. Then, i connect to imagery. after scan, it reports correct model and serial number but 0 capacity. what problem this hard drive has?
 Post subject: Re: seagate: 0 capacity
PostPosted: November 14th, 2013, 10:19
Seems like the usual bug : translator violation...
Easy with the correct tools or knowledge !
Lemmy
PostPosted: November 14th, 2013, 11:15
can you tell me what tools or knowledge?
PostPosted: November 14th, 2013, 11:31
7200.12 have NRG defect list. If you do not know what you are doing, or have no respectable tools for the job, you should not even try it.
PostPosted: November 14th, 2013, 14:43
thanks for your advice
PostPosted: December 8th, 2013, 7:52
Spildit wrote:
What would be the command to regen translator taking in account the NRG-List ? In other words, what would be the correct command to regen translator on a 7200.12 without damaging it further ?
Good question. I suspect this is done using the format command with FormatOpts = 6. But I'm not sure right now. Start by backing up all defects lists ;)
