 Post subject: seagate momentus terminal configuration
PostPosted: November 28th, 2013, 9:45
hi,
I have 2.5" seagate momentus 5400.6 320GB. I want to access via terminal serial. What is the settings for terminal program to use the serial port?
 Post subject: Re: seagate momentus terminal configuration
PostPosted: December 4th, 2013, 5:43
Spildit wrote:
I have one of those, but with 500 GB.
It's F3 Arch :
http://malthus.zapto.org/viewtopic.php?f=6&t=193
For 7200.11 (F3 Arch) and newer Seagate drives :
Bits per second - 38400
Data Bits - 8
Parity - None
Stop Bits - 1
Flow Control - None
hi,
I have usb to ttl serial. first I install driver then connect usb to ttl to PC. I go to device manager. usb to serial comm port (comm 5) appears. Then I connect to serial pin on hard drive. I start putty. when i press control+z, prompt does not appear. I cannot communicate with the drive. Can you tell me I do something wrong?
regards,
PostPosted: December 4th, 2013, 22:03
Spildit wrote:
Start by trying with Hyperterminal.
Maybe you have swapped TR/RX ?
Are you using the same power supply power on the drive and the adaptor ? If NOT you will need to plug Ground too.
Did you check the settings ?
When you power on the drive with the terminal already connected can you see some output on terminal ?
Thanks. I will try again.
PostPosted: December 8th, 2013, 3:49
Spildit wrote:
Please let us know if it worked :)
surely, I will let you know.
PostPosted: December 11th, 2013, 10:28
Usb to ttl adapter works. The result is in the attached file. Firstly, I must tell you some background. When I turn on power supply, the drive spins for a while then stops spinning. After that I cannot communicate via terminal program(putty) any more.
Thanks.
PostPosted: December 11th, 2013, 19:06
You cant communicate... Does this mean that Control+R does not give Online Mode, and Control+Z does not give F3 T> prompt(if it is an F3 drive)?
PostPosted: December 12th, 2013, 1:29
yes, right.
PostPosted: December 12th, 2013, 1:31
Spildit wrote:
Terminal is working as it should.
Drive is damaged as expected.
Do you need the data from the drive or what are you trying to do ?
I need the data from it. Is it possible? If yes, how? Thanks.
PostPosted: December 14th, 2013, 4:11
last time, I did something wrong so, i cannot issue any command. Now, I know and I try it again. The result is as follow:
what is your comment?
PostPosted: December 15th, 2013, 17:31
Bad heads.
