 Post subject: Recover VMware disk files
PostPosted: March 30th, 2014, 8:51
Hey Guys
I'm trying to recover a VMware virtual machine that I accidentally deleted from within VMware Workstation on Windows 7.
The vm I try to recover was running Windows 7 x64 encrypted with Truecrypt.
There were two vmdks. I'm not sure, but I think one was 100 GB and one was 50 GB (or maybe 150 GB).
I'm on Kali Linux right now.
I already made an image of the partition the vm was on with dd:
dd if=/dev/sdc3 of=img.dd conv=noerror
root@kali:/# ls -l -h img.dd
-rw------- 1 root root 832G Mar 30 13:31 img.dd
comming soon
The md5 hashes match:
2aa926de57834f395bcb6ff075cf03c8  /dev/sdc3
2aa926de57834f395bcb6ff075cf03c8  img.dd
Q1: Is this ok? Did I get all data there is? Can I boot and use the disk without hesitation of needing it later?
Then I used Photorec to extract the vmdks:
Disk img.dd - 892 GB / 831 GiB (RO)
     Partition                  Start        End    Size in sectors
      Unknown                  0   0  1 922646 101 14 1743802368 [Whole disk]
>   P NTFS                     0   0  1 922646 101 14 1743802368 [Data]
To recover lost files, PhotoRec need to know the filesystem type where the
file were stored:
[ ext2/ext3 ] ext2/ext3/ext4 filesystem
>[ Other     ] FAT/NTFS/HFS+/ReiserFS/...
Please choose if all space need to be analysed:
[   Free    ] Scan for file from NTFS unallocated space only
>[   Whole   ] Extract files from whole partition
root@kali:vmdk# ls -s -h recup_dir.1
total 832G
  27M f0334696.vmdk       55G f142349624.vmdk    342M f2350824.vmdk     6.0G f321178976.vmdk   9.0M f36528144.vmdk    9.3G f529270928.vmdk   310M f639895568.vmdk   648M f735741360.vmdk   1.5G f895917440.vmdk
  23M f0389928.vmdk      3.3G f1428779080.vmdk   3.6G f23537752.vmdk    320K f32184912.vmdk    3.7G f36546440.vmdk    863M f548680352.vmdk   1.2G f640530064.vmdk   9.0G f737067952.vmdk   1.3G f898972496.vmdk
389M f0435376.vmdk       16G f1435509520.vmdk    23M f257341952.vmdk   320K f32185552.vmdk    112M f381055728.vmdk   928M f550447624.vmdk   404M f642992448.vmdk   4.7G f74509320.vmdk    817M f901574976.vmdk
1.6G f1014391536.vmdk   5.7M f1467288.vmdk      3.6M f257388256.vmdk   320K f32186192.vmdk     11G f381284848.vmdk   212M f552347928.vmdk   540M f643818064.vmdk   3.4G f755776912.vmdk   2.4G f903247336.vmdk
720M f1017722736.vmdk   1.5G f1467536256.vmdk    16M f257395544.vmdk   8.8M f32186832.vmdk     62M f403672880.vmdk   162M f552781728.vmdk   1.3G f644923760.vmdk   1.8G f762863464.vmdk   206M f908236696.vmdk
4.8G f1019196264.vmdk   529M f1470639616.vmdk   2.7M f257427032.vmdk   155M f32204728.vmdk    772K f403798600.vmdk    63M f553112920.vmdk   102M f647535080.vmdk   4.1G f766481328.vmdk   692M f908657656.vmdk
  11M f1029142800.vmdk   1.3G f1471721472.vmdk   3.2M f257432408.vmdk   1.6G f32521528.vmdk     51M f403800144.vmdk   136M f553241304.vmdk    45M f647742552.vmdk   285M f775047064.vmdk   3.0G f910074152.vmdk
3.1M f1029164688.vmdk   819M f1474394240.vmdk   1.3M f257438960.vmdk   3.0M f333643264.vmdk   5.1G f403903280.vmdk   257M f553519472.vmdk   1.1G f647832824.vmdk   357M f775628952.vmdk   255M f916179040.vmdk
668M f1029170960.vmdk   369M f1476070400.vmdk   896K f257441520.vmdk   1.9M f333649312.vmdk    25M f414530608.vmdk    52M f554044048.vmdk   985M f650095864.vmdk   1.1G f776359448.vmdk   529M f916700000.vmdk
  29G f1030538024.vmdk   1.1G f1476824576.vmdk   3.0M f257443312.vmdk   320K f333653048.vmdk    94M f414580528.vmdk   955M f554149144.vmdk   3.8G f652112496.vmdk   2.2G f778521560.vmdk   1.9G f917782472.vmdk
364K f10434664.vmdk     186M f1478768.vmdk      1.8G f257449328.vmdk   320K f333653688.vmdk   2.4M f4146112.vmdk     3.5G f556103800.vmdk   742M f659967080.vmdk   773M f783131376.vmdk   1.1G f921665872.vmdk
6.3G f10435392.vmdk     796M f1478976896.vmdk   439M f261066320.vmdk   320K f333654328.vmdk    12G f414772784.vmdk   320K f56281456.vmdk    4.4G f661485328.vmdk   230M f784713872.vmdk   445M f923785104.vmdk
1.9G f1089792832.vmdk   430M f1480607104.vmdk   4.4G f261965152.vmdk   320K f333654968.vmdk   944K f4150848.vmdk     8.7G f56282096.vmdk    2.0G f670612160.vmdk   265M f785184656.vmdk   2.4G f924696096.vmdk
  16G f1093686472.vmdk   336M f1481486976.vmdk   8.6G f271102528.vmdk   320K f333655608.vmdk    76M f4152736.vmdk     506M f563429056.vmdk   1.7G f674803136.vmdk   242M f785726736.vmdk   809M f929612240.vmdk
  20G f1126974536.vmdk   1.5G f1482173312.vmdk   408M f289030408.vmdk   320K f333656248.vmdk   391M f4307984.vmdk     508M f564464512.vmdk   2.0G f678323392.vmdk   168M f786220560.vmdk   784M f931267848.vmdk
1.7G f115494408.vmdk    255M f1485277440.vmdk   2.0M f289865624.vmdk   320K f333656888.vmdk   173M f437933264.vmdk   1.5G f565503656.vmdk   1.8G f6815528.vmdk     207M f786563576.vmdk    11G f932872064.vmdk
108G f1167934784.vmdk   529M f1485798400.vmdk   814M f289869608.vmdk   320K f333657528.vmdk   2.7G f438286800.vmdk   245M f568511304.vmdk   1.4G f682516288.vmdk   1.5G f786986360.vmdk   1.8G f955376200.vmdk
320K f119013576.vmdk    1.3G f1486881152.vmdk    35M f291535784.vmdk   2.7M f333658168.vmdk   2.5G f44300304.vmdk    103M f569012848.vmdk   2.4G f685424472.vmdk   848M f790117312.vmdk   261M f959064080.vmdk
1.2G f119014216.vmdk    819M f1489553920.vmdk   2.5G f291605688.vmdk   2.4M f333663696.vmdk   233M f443800808.vmdk   237M f569223312.vmdk   175M f690299840.vmdk   4.3G f791853504.vmdk   539M f959597208.vmdk
1.1G f121391192.vmdk    369M f1491230080.vmdk    12M f296697800.vmdk   320K f333668416.vmdk   1.8G f444276128.vmdk   162M f569707128.vmdk   138M f690658152.vmdk   699M f800712912.vmdk   1.4G f960700544.vmdk
  34M f1230736.vmdk      1.1G f1491984256.vmdk    12M f296721968.vmdk   2.6M f333669056.vmdk   324M f447940856.vmdk   2.3G f570036888.vmdk    62M f690938864.vmdk   1.2G f802144344.vmdk   9.2G f96304488.vmdk
320K f123655144.vmdk    796M f1494136576.vmdk    62M f296746440.vmdk   320K f333674200.vmdk   197M f448604152.vmdk   5.0G f574682696.vmdk   113M f691065200.vmdk    18G f804525080.vmdk   837M f963564768.vmdk
6.2M f123655784.vmdk    430M f1495766784.vmdk   228M f296873400.vmdk   320K f333674840.vmdk   311M f449007528.vmdk   395M f584983752.vmdk    62M f691295928.vmdk    12G f840976592.vmdk   376M f965278608.vmdk
976M f123668304.vmdk     18G f1496646656.vmdk   279M f297339552.vmdk   320K f333675480.vmdk    71M f449643384.vmdk   184M f585791816.vmdk    91M f691420984.vmdk   905M f84342104.vmdk    1.6G f966047704.vmdk
7.8G f125666464.vmdk    101G f1533757808.vmdk   3.0G f297909984.vmdk   320K f333676120.vmdk   315M f449788024.vmdk   3.1G f586168328.vmdk   2.2G f691606712.vmdk   4.9G f86194752.vmdk   1007M f969225840.vmdk
6.1M f1300184.vmdk      1.5M f1859480.vmdk      173M f303995456.vmdk   320K f333676760.vmdk   2.0G f450431104.vmdk   2.5G f592657864.vmdk   111M f696066160.vmdk   8.0G f865705936.vmdk   532M f971287752.vmdk
  33M f1312552.vmdk      208K f1862520.vmdk       94M f304348504.vmdk   320K f333677400.vmdk   271M f454459640.vmdk   1.4G f597790168.vmdk    72M f696292336.vmdk    11M f882287920.vmdk   1.8G f972375480.vmdk
  19M f1378896.vmdk       48M f1862936.vmdk      2.7G f304540184.vmdk   320K f333678040.vmdk   138M f455012728.vmdk   852M f600623544.vmdk   436M f696439664.vmdk   3.1M f882309808.vmdk   9.5G f976047016.vmdk
2.7G f1392788904.vmdk    21M f1960696.vmdk      536M f3049832.vmdk     320K f333678680.vmdk   485M f455293688.vmdk   1.9G f602367600.vmdk   3.2G f697330728.vmdk   730M f882316080.vmdk   8.9G f995906592.vmdk
5.5G f1398446504.vmdk    36M f2002728.vmdk       36M f30889224.vmdk    3.3G f333679320.vmdk   320K f456285552.vmdk   4.3G f606325648.vmdk   115M f703988448.vmdk   1.6G f883809400.vmdk    68K report.xml
3.4G f1409937184.vmdk    27M f2075520.vmdk      1.5M f30962392.vmdk    1.6G f340498728.vmdk   320K f456286192.vmdk   2.9G f615224208.vmdk    53M f704223464.vmdk   586M f887063656.vmdk
5.7G f1416875552.vmdk    74M f2129960.vmdk      384K f30965464.vmdk    5.3G f343656672.vmdk   3.8G f456286832.vmdk   774M f621271016.vmdk    99M f704330096.vmdk   273M f888261776.vmdk
  25M f1416976.vmdk       23M f2281496.vmdk       47M f30966232.vmdk     30M f354617776.vmdk   2.0G f464141296.vmdk   3.7G f622854144.vmdk    30M f704530920.vmdk   750M f888819736.vmdk
143M f141887952.vmdk    7.2M f2327680.vmdk      5.3G f310143920.vmdk   3.3G f354678064.vmdk    30G f468313208.vmdk   228M f630530120.vmdk    11G f704591600.vmdk   1.4G f890354616.vmdk
  77M f142178936.vmdk    3.7M f2342320.vmdk      385M f31061840.vmdk    369M f35774200.vmdk    3.3G f49519992.vmdk    4.0G f630995416.vmdk    55M f727120528.vmdk   871M f893167200.vmdk
6.8M f142335728.vmdk    512K f2349800.vmdk      164M f31849248.vmdk    9.4G f361435968.vmdk   834M f5108272.vmdk     289M f639304720.vmdk   4.1G f727232016.vmdk   473M f894950656.vmdk
root@kali:vmdk# ls -1 recup_dir.1 | wc -l
319
Q2: Is this ok? should I do something in the advandec setting?
I then wrote a Python script to delete all the vmdks I can normally access by mounting the image.
I used their md5 hashes to compar them.
I then tried to use the Digital Foreniscs Framework to find the vmdks,
but it crashed a lot...
Q3: Is there any chance I will recover the vmdsk?
Thanks for your help!
 Post subject: Re: Recover VMware disk files
PostPosted: April 2nd, 2014, 15:32
ggnore,
q1 - yes, you can use your drive
q2,3 - i think what you tried could not produce the results you are looking for.
first, do you know what vmdk type those files were - dynamic (sparse) or flat?
second, those files were most likely fragmented (especially if they were dynamic), so scavenging would not work for it.
I'd try to analyse the file system and find any metadata left for those files. If they had attribute $20, it might give some additional options.
