 Post subject: WANTED: Seagate 7200.8 400gb HDD Contoller PCB
PostPosted: January 15th, 2021, 11:43
Hi, All,
I have a Seagate 7200.8 that is not spinning. I have continuity checked the diodes on the board, and none are shorting - and that is about the limit of my expertise. The power is on; the head tries to 'track' on the platter, but is prevented by the air-operated 'safety-catch', which appears to operated by the airflow from the spinning disks, and so it just click-click-clicks against the catch. The heads are moveable, and so is the platter-stack, so nothing is seized.
What I want to do is to swap out the PCB (where I believe the problem to be) for a replacement so that I can recover the data.
To that end, does anyone one out there have (or know where I might obtain) a controller PCB for;
Seagate Barracuda 7200.8 400GB
Model no. ST3400832A
Part no. 9Y7485-066
Firm ware 3.03
Date code 06135
Site Code TK
Any help would be really appreciated. I know it is an old HDD (and would normally be written off), however there are many 'brownie-points' to be earned with a very cute girl :wink: :lol:
Cheers for your time
Waltheof
 Post subject: Re: WANTED: Seagate 7200.8 400gb HDD Contoller PCB
PostPosted: January 15th, 2021, 13:12
99% it is not a pcb problem. More probably heads are bad and they do not kick the latch, rather just try to seek and then park, which is a kind of clicking.
Have you disassembled the HDA?
PostPosted: January 17th, 2021, 6:41
Hi, Pepe,
I'm not quite sure what you mean by "kick the latch".
The heads sit inboard (on the inside circumference) on the platter, and are physically incapable of opening the air-catch which the pivot end of the head-arm sits against. There is an air-channel alongside the platter which directs air onto the air-catch which the releases the head-arm.
As a mechanical engineer I can see how the air-catch works, and understand that it is there to secure the head-arm in the parked position if the platter is not spinning.
As I said in my original post - the platters do not spin-up when power is applied; which suggests an electronic problem rather than a mechanical one.
I appreciate your time in thinking about my problem, and if you have any suggestions I'd be grateful.
All the best.
Cheers
