HDD GURU FORUMS
http://forum.hddguru.com/
No Partition after motor controller swap
http://forum.hddguru.com/viewtopic.php?f=26&t=29374
Page 1 of 1
Author:  perigourbano [ August 27th, 2014, 19:25 ]
Post subject:  No Partition after motor controller swap
My HDD just died and I checked that the motor controller was burning hot so i order a new one that was the same model and replace it but after that I have no partition.
I did not change the pcb, only the chip.
Can anybody please help?
Author:  HaQue [ August 27th, 2014, 20:12 ]
Post subject:  Re: No Partition after motor controller swap
Which chip was it? post pics of the PCB both sides and specify model numbers of the drive.
Author:  perigourbano [ August 28th, 2014, 7:11 ]
Thanks a lot
The chip was a smooth l7251 3.1
The disk spins and identifys but says unknown partition
Author:  fzabkar [ August 28th, 2014, 7:30 ]
Does the drive identify itself with its full capacity?
Can you show us the contents of sector 0 with a disc editor (eg DMDE freeware)?
Author:  perigourbano [ August 28th, 2014, 10:06 ]
shows this...
Author:  perigourbano [ August 28th, 2014, 11:47 ]
New and old chip
Author:  fzabkar [ August 28th, 2014, 17:57 ]
It appears that the drive is OK and that you have installed it in a USB enclosure that is configured with a 4KB sector size. However, the serial number of your drive doesn't bring up a My Book product at WD's warranty verification URL. Therefore I'm wondering what kind of enclosure you are using, and whether the drive was originally installed inside your computer.
Could we also see the hexadecimal data in sector 0? (Select Mode -> Hexadecimal).
Author:  perigourbano [ August 29th, 2014, 9:20 ]
It's Working
Thanks a lot for your tips
I was using a usb adapter to connect to PC
I connected via SATA and voulá, everything was working again.
This is to show that such a great community of people could enlighten the dumbest ones (me) :D
Thanks again.
Author:  helpdisc [ August 30th, 2014, 5:02 ]
it would be nice to move topic to general topic, it does not have to do anything with hddsurgey now
http://www.phpbb.com/
