| WD5000BMVV 11GNWS0 MODULE 11 http://forum.hddguru.com/viewtopic.php?f=26&t=31467 |
Page 1 of 1 |
| Author: | shaikhmaula [ June 26th, 2015, 15:03 ] |
| Post subject: | WD5000BMVV 11GNWS0 MODULE 11 |
I have wD HDD model no :-WD5000BMVV 11GNWS0 the problem was it was getting detected but not showing me drive letter , it is Micro USB and MRTPRO dossent support micro USB so i imported Sata Card and change the U12 from Micro USb card to Sata card , After this what i need to so i dont now need some one who can help me as i am new to this field. Thanks |
| Author: | Jared [ June 26th, 2015, 18:04 ] |
| Post subject: | Re: WD5000BMVV 11GNWS0 MODULE 11 |
Most likely the data is encrypted, so unless you have PC-3000 (which can decrypt on the fly), you'll need to do the following: 1. Image the entire drive onto another hard drive (encryption key is stored at the end) 2. Set the destination drive's LBA to be exactly what the original drive's LBA was 3. Find a My Book USB bridge which uses the same encryption chip as the original PCB to decrypt it. Enjoy. |
