WD30NMWV Ramps
Posted: November 4th, 2015, 12:52
by Cleanroom
Got a new 3tb WD Passport in. 5 Platters, 10 Heads. It is a WD fatty size, not the standard 9.5mm. Just a heads up so we can see some ramps for it. Thanks
Re: WD30NMWV Ramps
Posted: November 29th, 2015, 16:40
by Amarbir[CDR-Labs]
Cleanroom wrote:Got a new 3tb WD Passport in. 5 Platters, 10 Heads. It is a WD fatty size, not the standard 9.5mm. Just a heads up so we can see some ramps for it. Thanks
Well,
Never seen anything till today more then 8 heads .This drive would be quite tough to handle without proper head tools .But still with some dedication its possible to swap heads using plastic medicine pill 2 cent head replacement tool .I have mastered to do a 8 head in few days using that method .it was very challenging
Re: WD30NMWV Ramps
Posted: December 5th, 2015, 4:38
by Milos_HddSurgery
Cleanroom wrote:5 Platters, 10 Heads.
Sounds like something we like to investigate :)
Re: WD30NMWV Ramps
Posted: December 5th, 2015, 15:22
Milos ,'
what these guys are doing is adding one platter after the other as they are not bothered about height in usb drives
Re: WD30NMWV Ramps
Posted: December 22nd, 2015, 18:04
by HardDrivesForSale
If you need head map of any of these for research purposes let us know https://www.harddrivesforsale.com/catal ... q=WD30NMVW
Re: WD30NMWV Ramps
Posted: December 12th, 2016, 13:09
by digisupport
Please investigate fast, done 3 of these this month with my own tools. Not as comfortable as yours :)
