| HDDS Horizontal Laminar Flow Cabinet M has arrived http://forum.hddguru.com/viewtopic.php?f=26&t=35235 |
Page 1 of 1 |
| Author: | Milos_HddSurgery [ April 10th, 2017, 10:22 ] |
| Post subject: | HDDS Horizontal Laminar Flow Cabinet M has arrived |
Dear colleagues, we present you our latest product: HDDS Horizontal Laminar Flow Cabinet M ![]() HddSurgeryTM Horizontal Laminar Flow Cabinet M is one of many steps that HddSurgery has taken in order to cover all the possible aspects of the daily needs of Data Recovery engineers. This time, HddSurgery advances into a new field, providing the adequate working environment, improving the quality of the work surroundings and thus increasing the success rate of Data Recovery activities. HDDS Horizontal Laminar Flow Cabinet M incorporates all the standard features of an ordinary Laminar Flow Cabinet, enhanced with several Data recovery oriented aspects. Our engineering team has accented the design and the visual appearance of this product, while maintaining the ergonomic requirements. Physical Dimensions: Height: 1625mm Width: 950mm Depth: 780mm Weight: 144kg Power supply: Input: 100-240 VAC (50/60 Hz) 3.5 A Rated power: 270 W Work Area Dimensions: 832,60 x 646,30 x 520mm Work table height: 700mm Airflow: 0.30 - 0.50m/s airflow velocity, adjustable via the touch screen Pre-Filter: Polyester fibers with 85% arrestance Main Filter: TROX™ Filter, H13, with >99,995% efficiency according to EN 1822. Cabinet Lighting: LED light panel 595x295mm, 4000K, up to 1950lx Noise: 70dB Side Windows: Construction Tempered Glass Visible Opacity: Semi-Transparent UV Opacity: UV Absorbing Color: Green Tint Construction: Color: White coated steel frame Work Surface: Stainless Steel Additional Features: Blower: Ebm-papst™ external rotor motor, permanently lubricated, low noise and vibration levels Electrical Controls: All controls are being handled via a touch screen Monitoring: Air Pressure, Temperature, Humidity Two MOLEX® ports with overload protection with retry Electrical characteristics: V5 = 5V +/- 0.25V V12 = 12V +/- 0.6V Check the PDF Manual, Promo teaser and Video guide. Follow us on Facebook to stay updated with the news from our company. |
| Author: | lifeguarddubai [ July 27th, 2017, 6:55 ] |
| Post subject: | Re: HDDS Horizontal Laminar Flow Cabinet M has arrived |
i ahve seen video on youtube could you send me Quotation via email thanks, info@lifeguarddatarecovery.com |
