 Post subject: HDDS Horizontal Laminar Flow Cabinet M has arrived
PostPosted: April 10th, 2017, 10:22
Dear colleagues, we present you our latest product:
HddSurgeryTM Horizontal Laminar Flow Cabinet M is one of many steps that HddSurgery has taken in order to cover all the possible aspects of the daily needs of Data Recovery engineers. This time, HddSurgery advances into a new field, providing the adequate working environment, improving the quality of the work surroundings and thus increasing the success rate of Data Recovery activities.
HDDS Horizontal Laminar Flow Cabinet M incorporates all the standard features of an ordinary Laminar Flow Cabinet, enhanced with several Data recovery oriented aspects. Our engineering team has accented the design and the visual appearance of this product, while maintaining the ergonomic requirements.
Physical Dimensions:
Height: 1625mm
Width: 950mm
Depth: 780mm
Weight: 144kg
Power supply:
Input: 100-240 VAC (50/60 Hz) 3.5 A
Rated power: 270 W
Work Area Dimensions:
832,60 x 646,30 x 520mm
Work table height: 700mm
Airflow:
0.30 - 0.50m/s airflow velocity, adjustable via the touch screen
Pre-Filter: Polyester fibers with 85% arrestance
Main Filter: TROX™ Filter, H13, with >99,995% efficiency according to EN 1822.
Cabinet Lighting:
LED light panel 595x295mm, 4000K, up to 1950lx
Noise: 70dB
Side Windows:
Construction Tempered Glass
Visible Opacity: Semi-Transparent
UV Opacity: UV Absorbing
Color: Green Tint
Construction:
Color: White coated steel frame
Work Surface: Stainless Steel
Additional Features:
Blower: Ebm-papst™ external rotor motor, permanently lubricated, low noise and vibration levels
Electrical Controls: All controls are being handled via a touch screen
Monitoring: Air Pressure, Temperature, Humidity
Two MOLEX® ports with overload protection with retry
Electrical characteristics:
V5 = 5V +/- 0.25V
V12 = 12V +/- 0.6V
Check the PDF Manual, Promo teaser and Video guide.
Follow us on Facebook to stay updated with the news from our company.
 Post subject: Re: HDDS Horizontal Laminar Flow Cabinet M has arrived
PostPosted: July 25th, 2017, 10:37
Special offer from HddSurgery
Since the release (and even before), our HDDS Horizontal Laminar Flow Cabinet M has been a great success and a lot of DR companies wanted to have it in their offices.
But, not all companies have the conditions to actually purchase it.
From the start our mission was to provide professional data recovery equipment for all our colleagues in the world.
As we understand the importance of having a clean cabinet in every lab, we decided to give a special discount for August 2017.
Together we can create a better data recovery service for all customers!
PostPosted: July 27th, 2017, 6:55
i ahve seen video on youtube could you send me Quotation via email thanks,
info@lifeguarddatarecovery.com
