SeaGate ST1000DM003 not accessible
http://forum.hddguru.com/viewtopic.php?f=26&t=35514
Author:  pdelap [ June 25th, 2017, 12:14 ]
Post subject:  SeaGate ST1000DM003 not accessible
Drive suddenly is no more accessible, apparently after powering on/off
I tried to access with external usb connector.
It does spin, and no special noise like tic tic is heard.
On windows 10 disk management, when I see the disk (not always), it seems not initialized.
some times (like 1% of times when reconnected) it tries to open the various partitions (about the 5 partitions) openning various explorer windows, but never suceeds.
using seagate tool (i noticed it appears in the tool after being up since some 15 minutes either it is not visible yet), the SMART test does not do anything,
The other tests are successfull including the full test
I got connected via tx/rx on the hard drive, via USB and COM port, using an Arduino (reset shunted to the GND, TX/RX connected but with voltage bridget of 220 Ohm for each connection).
Connection at 38400 bds
It gives me this when I switch on the hard drive :
Boot 0x40M
Spin Up[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40125B10 40122EE8
Seg Write Preamble VBM start: 0000204A end: 00002091
Footer - start: 00002093 end: 000020DA
Seg Read Preamble VBM - start: 000020DC end: 00002123
Footer - start: 00002125 end: 0000216C
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0006CCFF
[RSRS] 00ED
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
PowerState = IDLE1
PowerState = IDLE2
APM disabled by Sport
Not that between the IDLE2 and APM disabled by Sport line, I had to wait some 15 minutes.
After ore than 30 minutes, nothing moves anymore
If I switch on/off the HD it does again the same.
I cannot send any command apparently (while the RX light on the arduino seems to work each time I press a key)
Note : I have lots of photos on this hard drive and would not like to loose them. For other stuff, it would be a pitty, but I will assume.
File comment: log when HDD is switch on
HDD Seagat ST1000DM003 Initial Logv1.txt [894 Bytes]
Downloaded 1772 times
Author:  Martin [ June 25th, 2017, 14:32 ]
Post subject:  Re: SeaGate ST1000DM003 not accessible
Ctrl+Z?
And what kind of equipment/tools do you have?
Author:  pdelap [ June 25th, 2017, 18:35 ]
I'm sorry I didn't get your question.
Ctrl z has no more effect than any other entry, as said, whatever the terminal tool used.
I do no understand what I can detail more precisly about the equipment : st1000dm003 for thé HD, a pc connected with USB and an arduino, with a connection that works. ...
Author:  Martin [ June 25th, 2017, 19:19 ]
I was asking is there any response onto Ctrl+Z after last string.
And wanted to know what do you have to work with such cases, I meant any professional tools.
You have, at least, to try restart drive with shorten read channel sending Ctrl+Z to set drive in command mode.
Or, if you are sure that drive is ok physically, no visible damages, no unusual noises etc., just try to leave it for 2-3 hours and try to manage it again.
Author:  pdelap [ June 26th, 2017, 15:10 ]
No no answer even if i waited 1 hour
I tried to cztch ctrl z by starting it and typing it quickly but couldnt get it
What about the log. Does it stop at an end point or shall it say more ?
Do you think my tx usb mode may be deficient ? Seems not as i can see the tx atduino led flashing each key i press
Author:  fzabkar [ June 26th, 2017, 16:24 ]
@pdelap, you can locate the read channel as follows:
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
Author:  Martin [ June 26th, 2017, 17:29 ]
Because the drive is too busy to answer on it. You have to do it with shorten channel. Apply shortening immediately after string "(P) SATA Reset"
Yes, this is the last stage.
If you provide a photo I will mark a contacts to shorting.
Author:  pdelap [ June 26th, 2017, 18:18 ]
Attached photo of the boot of the electronic catd. Will inscrew it tomorrow for it. Pomhoto sampkes shall be ok. What do you mean by shrten ? Shall i do a short circuit on the read xhannel ? Short circuit with what ?
