| File lists from Clone Disc - Job organizer 3.13 http://forum.hddguru.com/viewtopic.php?f=26&t=37353 |
Page 1 of 1 |
| Author: | Milos_HddSurgery [ September 7th, 2018, 7:05 ] |
| Post subject: | File lists from Clone Disc - Job organizer 3.13 |
HddSurgery Job organizer 3.13 3.2 File lists (Cloning to Disc - PC3000) The File list is one of the main advantages of the Job Organizer software. This feature provides a fast and simple way to check the damaged files both online and offline. Your client will get the same files and folders structure as they had in their devices before the malfunction. Offering such service will provide a significant competitive advantage for your business. You will get the competitive advantage for offering such service. As there are different methods of cloning, we have prepared the list of three tutorials for creating a File list. The first tutorial presented how to create a file list using ''cloning to file - Image'' method. You may find it here. The second tutorial in this thread shows how to create a file list using ''cloning to Disc'' method. New Video: HddSurgery Job Organizer - File lists (Cloning to Disc - PC3000)
| Author: | lcoughey [ September 7th, 2018, 7:25 ] |
| Post subject: | Re: File lists from Clone Disc - Job organizer 3.13 |
It is too bad DeepSpar's Operations server didn't kick off. With their file list, the client was able to select the specific files and folders they wanted recovered and that selection would be pushed to the Disk Imager selected sector map to be imaged. |
| Author: | helpdisc [ September 7th, 2018, 8:13 ] |
it would mean that hdd should be powered on and wait until client wakes up? Anyhow does not have to do much with our solution |
| Author: | lcoughey [ September 7th, 2018, 10:41 ] |
helpdisc wrote: it would mean that hdd should be powered on and wait until client wakes up? Anyhow does not have to do much with our solution No, basically, at this point, the drive would have only been powered on long enough to read the file structure and then powered off and/or set aside until they respond with their selection. When you reconnect the project to the imager, you (the tech) would need to import the client selected file sector map and start imaging only the selected sectors. When done, DDI would verify the targeted files and update the file listing showing the good and damaged files for the client to approve the final recovery result. |
| Author: | helpdisc [ September 7th, 2018, 10:55 ] |
on damaged structure it would not work, on raids it would not work. You would have to turn on hdd at least one more time witch it self can be a problem. Ddi it self is limited. Etc etc etc....we made universal solution integrated in job tracking sistem. Recovery engineers can focus on jobs and juniors can do easer jobs like copy and make file list. We use it for last 12 years....long before it was must have in most of data recovery companies. |
| Author: | lcoughey [ September 7th, 2018, 14:29 ] |
I don't question your system, just making an observation. If it weren't such a pain to switch systems, I'd probably consider migrating to your system. |
| Author: | pclab [ September 8th, 2018, 13:41 ] |
Nice tool! |
| Author: | helpdisc [ September 10th, 2018, 3:34 ] |
Thanks ,and thanks |
| Author: | lcoughey [ September 10th, 2018, 9:53 ] |
Any chance that you might be interested in selling the file reporting separate to the job manager? |
| Author: | pclab [ September 10th, 2018, 18:13 ] |
lcoughey wrote: Any chance that you might be interested in selling the file reporting separate to the job manager? I was thinking of that too... |
| Author: | Milos_HddSurgery [ September 18th, 2018, 3:26 ] |
HddSurgery Job organizer 3.13 3.3 File lists (UFS/R Studio) The File list is one of the main advantages of the Job Organizer software. This feature provides a fast and simple way to check the damaged files both online and offline. Your client will get the same files and folders structure as they had in their devices before the malfunction. Offering such service will provide a significant competitive advantage for your business. You will get the competitive advantage for offering such service. As there are different methods of cloning, we have prepared the list of three tutorials for creating a File list. The first tutorial presented how to create a file list using ''cloning to file - Image'' method. You may find it here. The second tutorial presented how to create a file list using ''cloning to Disc'' method. The third and the last video presents how to create a file list using ''cloning to disc'' method on PC3000 and UFS for data extraction. New video: HddSurgery Job Organizer File list (UFS, R studio...)
