Broke BIOS chip and Need Help
Posted: December 22nd, 2022, 14:11
Hello All!
I recently had a drive start failing Toshiba Dt01aca200 2Tb drive and thought it was the read write head so I replaced that only to have it MSI boot once. Turned the pc off and back on and it wouldn't boot again so I figured it had to be some issue with the motherboard. In trying to transfer the old BIOS chip off the old board I broke a pin off the corner. Should have used rework station hot air and am now reaping the consequences of using a soldering Iron:( So now I am here, with the old motherboard my MSI bios wouldn't even boot let alone windows 10 and would get stuck. In installing the new motherboard the drive now boots ie spins up and does a head search and MSI and windows boot normally. My Issue is when I go to disk management it wants to initialize the drive showing an unknown disk and disk size. I want the data off the drive it is important to me so no initialize. When I go to device manager it is shown as an unknown device, windows says its "working properly" and even shows the options to uninstall or update drivers but explore cant see the drive. Can software like Clonezilla or DDrescue work on a drive despite the BIOS Chip being the wrong one. When they clone sector by sector is the BIOS bypassed or?
Thank yall,
Tyler
Thank yall,
Tyler
