 Post subject: Monolith Pinout - WP pin
PostPosted: January 6th, 2020, 8:36
Hello everyone.
I am trying to recover this flash, but missing WP pin from the diagram. I don't have logic analyzer here to find it, maybe one of you has it?
Help much appreciated.
 Post subject: Re: Monolith Pinout - WP pin
PostPosted: January 6th, 2020, 10:35
yco wrote:
Hello everyone.
You usually don't need need the WP pin.
PostPosted: January 6th, 2020, 12:11
WP is not important.
PostPosted: January 6th, 2020, 12:25
I am aware of that. This chip has a lot of byte errors. I played with voltage levels without positive results. I was told by a colleague that actual read-retry routines in VNR won't be effective without WP signal. Is that correct?
PostPosted: January 6th, 2020, 13:22
IMHO no :) Try read this dump with slow mode or connect VCCq instead VCC.
PostPosted: January 6th, 2020, 14:00
I will try that tomorrow.
Thanks.
PostPosted: January 7th, 2020, 12:27
Could you send screenshot of 'Read Memory Chips' Window?
