 Post subject: Sandisk Extreme Pro 64GB Pinout?? Recovery???
PostPosted: October 13th, 2022, 12:03
Hi everyone,
I got an SD card formatted with a Fuji Camera, trying to get the data back
Can you guys help me out. If can, tell the specifics of the process.
I just started out, still learning stuff
1st i want to find the Pin Description? is this SDHC Type 4
https://ibb.co/PTW9NTZ
 Post subject: Re: Sandisk Extreme Pro 64GB Pinout?? Recovery???
PostPosted: October 13th, 2022, 15:50
Is it trimmed/zeroed then? Did you check this first?
For example, DMDE in partition TAB click 'advanced'. In hex view what does it look like 20% or so into drive? And 30, 40%. If you see 'random' data you can just try a file recovery tool.
PostPosted: October 13th, 2022, 16:24
I answer you at Aclab forum already. So once again:
If your card is http://odzyskiwanie-danych.com.pl/image ... arvika.jpg chip-off is not an option at current day, due to LDPC correction algorithm. Probably this card use encryption also.
