 Post subject: SanDisk NAND unknown model/layout
PostPosted: February 20th, 2023, 14:54
Hi all,
I have a SanDisk Cruzer Glide 16GB with the following NAND (see attached pic). It is a BGA132
Wired it up and chip ID reads as 454CA4937A. I cannot find this in VNR database and cannot find a close match OR any documentation on NAND model from info printed on IC.
Has anyone come across this one before and know the config for it?
Thank you.
 Post subject: Re: SanDisk NAND unknown model/layout
PostPosted: February 20th, 2023, 19:04
Check this one.
PostPosted: February 21st, 2023, 15:00
arvika wrote:
Check this one.
I believe everything is correct except block size on mine seems like it is actually 8
Thanks!
