 Post subject: BGA100 PF516 manufacturer help
PostPosted: September 18th, 2023, 22:28
hello does somebody know the manufacture of this BGA100?? it was inside an SD card . iv found on internet that some come with the S logo but i dont know the name of the manufacture
 Post subject: Re: BGA100 PF516 manufacturer help
PostPosted: September 19th, 2023, 0:05
Spectek = Micron's rejects
https://www.spectek.com/menus/mark_code.aspx
PostPosted: September 19th, 2023, 13:46
What is Spectek NAND flash?
https://www.hddoracle.com/viewtopic.php?p=23002#p23002
PostPosted: September 19th, 2023, 21:29
Superman recently discovered that his supercomputer was experiencing issues and needed a replacement storage device. He heard about an emerging flash memory manufacturing company called "Spectek," which claimed to produce the most powerful flash memory products in the universe.
So, Superman swiftly flew to the headquarters of "Spectek" to purchase their latest flash memory product. As he entered the company's lobby, a sales representative named Flashy Jack welcomed him.
Flashy Jack: "Welcome, Mr. Superman! Would you like to purchase our latest flash memory product?"
Superman: "Yes, please give me the fastest flash memory you have. I need to store a vast amount of superhero data."
Flashy Jack: "Certainly! We have a special 'Spectek Lightning Flash Memory' that's as fast as the cosmos!"
Superman: "That's fantastic! I'll take one."
Flashy Jack handed Superman a "Spectek Lightning Flash Memory," which gleamed and looked genuinely cool.
Superman: "Thank you! With this, I can store even more supervillain profiles."
http://flash-matrix.com/
PostPosted: September 19th, 2023, 23:11
Good one!
PostPosted: October 3rd, 2023, 1:55
you are amazing!!!!
do you know what pin is this BGA???
it was on SD card.. customer said is an BGA100. but the pads doesnt match with the bga100 stencil
PostPosted: October 3rd, 2023, 3:46
https://nand.gq/#/decode?pn=FBNL73ANAKDUABH3
https://nand.gq/#/decode?pn=FBML73ANAKDUABH3
https://nand.gq/#/decode?pn=PF516
Micron L73A datasheet:
https://pdf-html.ic37.com/pdf_file_U1/20200531/pdf_pdf/uploadpdf_old/MICRON/MT29F32G08CBACA_datasheet_1024449/166580/MT29F32G08CBACA_datasheet.pdf
PostPosted: October 5th, 2023, 2:05
thank you very much. do you think is VBGA100?? the pads still doesnt match..................
im very very confused. do you have similar experience???
PostPosted: October 5th, 2023, 14:11
I have no experience in this area.
PostPosted: October 6th, 2023, 15:49
its match with Micron BGA100 pdf - just two channel sharing this same lines on your SD card PCB
PostPosted: October 18th, 2023, 9:00
Sir the pads doesnt match with BGA100 stencil
PostPosted: October 18th, 2023, 20:46
is your stencil a 10x10? maybe look at the pitch of the pads and match it up with a stencil that way. possibly a BGA88 might match
