 Post subject: WD Green Sandisk 20-80-00496-2 With 4 BGA 132 [New NAND ID]
PostPosted: June 14th, 2023, 12:32
Hello ,
Not Sure If This is Yet Another Rusolut Adapter Error ,But This is a NAND ID I am Getting
New NAND ID " 45489AB37E6B081E "
 Post subject: Re: WD Green Sandisk 20-80-00496-2 With 4 BGA 132 [New NAND
PostPosted: June 14th, 2023, 12:41
Why don't you solder them and check?
ID is fine. Stop blaming everything on adapters. They are just making your life easier.
odzyskiwanie danych
PostPosted: June 14th, 2023, 19:16
It's mostly here:
https://ripitapart.com/tag/45-48-9a-b3/
PostPosted: June 14th, 2023, 23:35
Nice ,
If ID is fine ,i have raised a ticket ,This is a new ID not in database ,i used a config that i think should be it and read a chip U5 , now i am eccing it .Yes i have a defective lot of all adapters ,I am convinced i have em ,More on the adapter part later on ,in a different post .I have two WD Green SSD Cases To handle lets see how it goes .
PostPosted: June 15th, 2023, 0:12
After 0x7E i Have 0x6B ,And according to your link Last 2 Bytes is no information in datasheet ,Buttttttt in my case its 0x08 0x1E
PostPosted: June 15th, 2023, 3:53
ID is correct. Block = 1152 pages.
PostPosted: June 15th, 2023, 12:05
Hi Michael ,
Can you please share a screenshot of the config in VNR Please
PostPosted: June 15th, 2023, 14:09
Updating Thread ,
The M.2 SATA i have for another case is also Same ID , For Rusolut Guys This ID is Fairly " IN USE "
PS : Atleast in India
PostPosted: June 18th, 2023, 12:15
Guys ,
This Was the Config ....
PostPosted: January 23rd, 2024, 11:20
Hello, I have same SSD with this chip ID. Is there a solution for this case? Thank you
