 Post subject: Function for periodically occurring bad bits in FC2279 -Idea
PostPosted: August 5th, 2024, 8:46
Hello, have you had any experience with periodically occurring bad bits in a damaged plane? We have a new case based on the FC2279 controller, the problem is that the block has 1536 bad bits, cutting them out manually is time-consuming and it could be done with one mouse click after entering 2 parameters in VNR - the location of the first bad bit and the period of occurrence.
Below you will find an example in the screenshot I have attached: in our case, the first bad bit column is in position 13, the next ones are 109, 205, 301... etc. so the period is 96 bits.
I think it's nice that a function has been implemented in VNR that will do it for us automatically.
Is it possible to develop such a function in VNR?
ps. after removing these bad bits, I have ECC and I can see the data, so it is not a garbage block.
Best regards.
 Post subject: Re: Function for periodically occurring bad bits in FC2279 -
PostPosted: August 6th, 2024, 12:22
That is impressive that you removed 1536 bad bits manually :shock:
I think if we meet more such cases, we'll do it.
