| Adding Banks http://forum.hddguru.com/viewtopic.php?f=27&t=36300 |
Page 1 of 1 |
| Author: | ddrecovery [ January 11th, 2018, 13:52 ] |
| Post subject: | Adding Banks |
Can someone remind me the best way to add Banks into a case retrospectively, ie without losing page structure already completed. |
| Author: | Sasha Sheremetov [ January 11th, 2018, 14:14 ] |
| Post subject: | Re: Adding Banks |
Go back to the Root in source structure (or you can edit structure of markers table) remove Block and add Bank (divide your dump size by number of banks to get a bank size). Then don't forget to add Block into newly created Bank structure. You won't loose page structure unless you do edit inside the page. |
| Author: | ddrecovery [ January 11th, 2018, 16:21 ] |
Sasha Sheremetov wrote: Go back to the Root in source structure (or you can edit structure of markers table) remove Block and add Bank (divide your dump size by number of banks to get a bank size). Then don't forget to add Block into newly created Bank structure. You won't loose page structure unless you do edit inside the page. Thanks Sasha. Banks added. Do I need to specify a Bank position under Bank structure? If so how? |
| Author: | Sasha Sheremetov [ January 11th, 2018, 16:57 ] |
Nope, no need. Just select your Bank structure from drop down box in Markers table. P.S. Revising now this Bank feature, will simplify it, I see it's kinda too many steps to do such a simple thing. |
| Author: | ddrecovery [ January 11th, 2018, 17:09 ] |
Thanks Sasha. |
