Automatic Bad Column Removal
Posted: August 28th, 2018, 19:48
How does the new Bad Column Removal tool work? and where does the element fit into the case?
Rusolut if you are watching, in support you have two example cases at the bottom of the linked page, but both appear to link to the 'old fashioned' way of removing bad columns. I presume one of these links should take you to how the new tool works.
https://rusolut.com/nand-bad-columns-an ... nd-removal
Any help would be appreciated.
