Monolith Pinout - WP pin
http://forum.hddguru.com/viewtopic.php?f=27&t=39330
Author:  yco [ January 6th, 2020, 8:36 ]
Post subject:  Monolith Pinout - WP pin
Hello everyone.
I am trying to recover this flash, but missing WP pin from the diagram. I don't have logic analyzer here to find it, maybe one of you has it?
Help much appreciated.
Author:  ddrecovery [ January 6th, 2020, 10:35 ]
Post subject:  Re: Monolith Pinout - WP pin
yco wrote:
Hello everyone.
You usually don't need need the WP pin.
Author:  arvika [ January 6th, 2020, 12:11 ]
WP is not important.
Author:  yco [ January 6th, 2020, 12:25 ]
I am aware of that. This chip has a lot of byte errors. I played with voltage levels without positive results. I was told by a colleague that actual read-retry routines in VNR won't be effective without WP signal. Is that correct?
Author:  arvika [ January 6th, 2020, 13:22 ]
IMHO no :) Try read this dump with slow mode or connect VCCq instead VCC.
Author:  yco [ January 6th, 2020, 14:00 ]
I will try that tomorrow.
Thanks.
Author:  p_patryk [ January 7th, 2020, 12:27 ]
Could you send screenshot of 'Read Memory Chips' Window?
