 Post subject: UFS BGA254 (and other UFS) support
PostPosted: December 19th, 2022, 18:06
Hi all!
I haven't seen or been able to find anything on this, but does anyone know if VNR or Rusolut in general have UFS adapters?
Another thought I had was REing a UFS chip for fun to see if it is possible to access NAND via VNR. Does anyone have a datasheet for any BGA254 UFS ICs as I have also not been able to stumble across any of those.
 Post subject: Re: UFS BGA254 (and other UFS) support
PostPosted: December 19th, 2022, 18:18
There is no UFS adapter for VNR.
PostPosted: December 19th, 2022, 19:07
Can anyone recommend a good adapter+software system for handling UFS?
PostPosted: December 20th, 2022, 5:32
NuProg.
PostPosted: December 20th, 2022, 14:45
If you need to read it via standard MPHY/MPHY-II protocol then Medusa PRO II, NuProg E2, MiPi BOX - adapters for 254/153 and 95 are available for them
If you need to have NAND adapters for UFS we plan to release some of them in new year but you need to know that all UFS use LDPC for correction (doesn't use BCH)
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
