WD Green Sandisk 20-80-00496-2 With 4 BGA 132 [New NAND ID]
http://forum.hddguru.com/viewtopic.php?f=27&t=43409
Author:  Amarbir[CDR-Labs] [ June 14th, 2023, 12:32 ]
Post subject:  WD Green Sandisk 20-80-00496-2 With 4 BGA 132 [New NAND ID]
Hello ,
Not Sure If This is Yet Another Rusolut Adapter Error ,But This is a NAND ID I am Getting
New NAND ID " 45489AB37E6B081E "
Author:  melvin [ June 14th, 2023, 12:41 ]
Post subject:  Re: WD Green Sandisk 20-80-00496-2 With 4 BGA 132 [New NAND
Why don't you solder them and check?
ID is fine. Stop blaming everything on adapters. They are just making your life easier.
Author:  fzabkar [ June 14th, 2023, 19:16 ]
It's mostly here:
https://ripitapart.com/tag/45-48-9a-b3/
Author:  Amarbir[CDR-Labs] [ June 14th, 2023, 23:35 ]
Nice ,
If ID is fine ,i have raised a ticket ,This is a new ID not in database ,i used a config that i think should be it and read a chip U5 , now i am eccing it .Yes i have a defective lot of all adapters ,I am convinced i have em ,More on the adapter part later on ,in a different post .I have two WD Green SSD Cases To handle lets see how it goes .
Author:  Amarbir[CDR-Labs] [ June 15th, 2023, 0:12 ]
After 0x7E i Have 0x6B ,And according to your link Last 2 Bytes is no information in datasheet ,Buttttttt in my case its 0x08 0x1E
Author:  arvika [ June 15th, 2023, 3:53 ]
ID is correct. Block = 1152 pages.
Author:  Amarbir[CDR-Labs] [ June 15th, 2023, 12:05 ]
Hi Michael ,
Can you please share a screenshot of the config in VNR Please
Author:  Amarbir[CDR-Labs] [ June 15th, 2023, 14:09 ]
Updating Thread ,
The M.2 SATA i have for another case is also Same ID , For Rusolut Guys This ID is Fairly " IN USE "
PS : Atleast in India
Author:  Amarbir[CDR-Labs] [ June 18th, 2023, 12:15 ]
Guys ,
This Was the Config ....
Author:  martyjelen [ January 23rd, 2024, 11:20 ]
Hello, I have same SSD with this chip ID. Is there a solution for this case? Thank you
