Everything related to MRT tools
December 19th, 2014, 3:20
Hi
I need LDR for this hdd.
- Attachments
December 19th, 2014, 7:48
What ROM version?
December 19th, 2014, 10:43
pclab wrote:What ROM version?
I don't know, this hdd detect as a model only!
No FW, No ROM version...
MRT engineer says need to load LDR
December 19th, 2014, 13:40
If you can read the ROM you can find the ROM version around line 0x3D750 just under the letters ROYL if you view it in Hex. It should be something like 00200049 or similar.
December 20th, 2014, 2:01
ROM Version: 01.32B
December 20th, 2014, 12:16
Post the ROM file here. It's better.
December 21st, 2014, 3:17
ROM create with MRT
- Attachments
ROM_WDC WD20EZRX-00D8PB0.txt
- (512 KiB) Downloaded 1229 times
December 21st, 2014, 8:10
upload rom.bin file after compressing it.
December 21st, 2014, 9:01
00010032 is the rom version you are looking for the loader.
Good Luck
December 21st, 2014, 9:18
Convert .txt to .bin
December 21st, 2014, 10:33
databack wrote:Convert .txt to .bin
forget it, got the info required.
now wait if someone has this FW: 00010032
