 Post subject: WD My Book encryption
PostPosted: March 16th, 2016, 11:04
Hello.
Need help with this case. I have got this 3tb my book drive (WD 30EZRx), its locked and MRT fails unlocking it!
Usually WD drives are unlocked from a single command from the MRT interface. It asks from unlocking but it failed for this one.
Attached the MRT log with the file. Any solution to this?
File comment: Mrt Log
 Post subject: Re: WD My Book encryption
PostPosted: March 16th, 2016, 13:04
I suggest you contact MRT tech support.
PostPosted: March 16th, 2016, 13:40
i can help you with this but you have to send drive to me.
Data Recovery Pakistan
PostPosted: March 16th, 2016, 15:59
I have forwarded the case to MRT. I hope they will be able to help access the data from this SED drive.
PostPosted: March 17th, 2016, 2:40
Spildit wrote:
This is SED. As far as i know MRT products can't handle it. You will need PC-3000.
we have express edition. :)
PostPosted: March 17th, 2016, 2:44
Wasim,
Possibly They Cannot Imagine a Pakistani Having High End DR Gear ,Keep It Up Man chakdey .Any Luck With The Loader I Gave you For WDC .Might Be We Both Can Play Around With The SA To Gain User Data Access
