 Post subject: HD seagate model: ST2000LM007-1R8174 unmatched capacity
PostPosted: January 10th, 2019, 15:38
Hi everyone, I have problem for this disk and I do not find topic for solution, can anyone help?
Disk slows down for a long time to identify and does not go into terminal mode.
 Post subject: Re: HD seagate model: ST2000LM007-1R8174 unmatched capacity
PostPosted: January 10th, 2019, 16:23
The hd rotates normally, but beeps twice as soon as it is turned on, it takes time to exit BSY mode and clicking Auto-identification goes to the wrong family with errors.
Thanks for the information, I'll be checking another hd from the same family about the behavior that will present.
PostPosted: January 10th, 2019, 18:18
Thank you, I will.
PostPosted: January 11th, 2019, 0:19
First You need to check Terminal log ..
PostPosted: January 11th, 2019, 2:41
“Beeps twice” is almost certainly physical issues, don’t mess with it any further!
PostPosted: January 11th, 2019, 2:42
Absolutely, no doubt it will show servo errors.
PostPosted: May 19th, 2019, 20:25
Disk is Port Locked.
You need to "firmware unlock" and "exchange commands".
Try to identify HDD again. Capacity should be detected normally.
Users browsing this forum: Google [Bot] and 7 guests
