Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST31000524AS - FW:HP64 PCB:100574451 REV B - (pcb is BUR
PostPosted: September 12th, 2021, 3:02
pepe wrote:
Have you tried external readers? Yes
with desoldering the patient rom? YES
coz you may not be able to read it in circuit if the power rail is shorted for example.
soldered it to donor pcb? Yes
Read it VIA MRT ROM READER
Let me say Again - IT IS CONFIRMED ORG ROM IS BLANK.
1. Only ROM Read via MRT ROM reader (result : Blank)
2. Putting on Donor PCB - Read via BOOT CODE (result : Blank)
Is there any way to Re-build the ROM (manually or automated) ? will be the best way to get the data.
PostPosted: September 14th, 2021, 5:41
yes, as i said i can do it.
Just tried to exclude any other problems that might have suggested that the rom is empty while it actually isn't, before moving to the rom recovery phase.
No bitcoin donations :)
PostPosted: September 15th, 2021, 2:33
Thanks for the Reply. :cool:
