Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD WD10EURX-61UY4Y0,Trailxlb, Logical Scan Test failed
PostPosted: February 17th, 2023, 3:31
I know that following action taken is not 100% correct, but in time being [SOLVED] my problem. Due to need data urgently and need to solve before week end,
I done with DE successful :
DE about 30%, then manually I stop.
Mount the drive, in read mode
Activated R-Studio, scan and read file, saved those read file.
It is successfully, although small amount bad files skipped.
Thanks.
PostPosted: February 19th, 2023, 23:17
Spildit wrote:
KangKung wrote:
Spildit wrote:
I would empty the re-lo table for sure. That one is loaded to RAM causing the slow down. Your report show sectors pending reloaction so your re-lo list have entries so the drive is processing those and getting stuck and slow.
Also it's not a repair and it's not by ID ... It simply read/write module 02 (aparently by ID) and patch it. At any rate select by ID and tick the 4 boxes on repair options.
Power off/on. IMAGE THE DRIVE if possible by heads and check if some of them read faster than the others and if some have errors, etc ...
Spildit,
Module 2 how to patch in MRT? I am not found to do it in MRT.
Just for reference :
http://www.hddoracle.com/viewtopic.php?f=86&t=848
Glad you did manage to get the data that you needed.
Thanks for the information, that it a bunch of the WD in my stock with the same issue .
