 Post subject: MER Programmer 2.0
PostPosted: June 19th, 2023, 22:53
Banned User
I have programmer 2.0 and it has troubles unlocking firmware after reading the ROM chip. has anyone faced same issue? tried to contact MRT they said Programmer 3.0 Is required. I was wondering if there is any way that can unlock with 2.0?
thanks
 Post subject: Re: MER Programmer 2.0
PostPosted: June 20th, 2023, 1:16
You will need MRT 2171 old version....read here
https://forum.hddguru.com/viewtopic.php?f=28&t=41721
Rgds
www.datasave.ro
PostPosted: June 20th, 2023, 10:33
Rgds
MRT Said This " 3. Fixed the problem about failure to unlock PCB 810035. For version 2173 we need to choose 800022 to unlock 810035 "
PostPosted: June 21st, 2023, 1:37
Since MRT 2171(new) version to unlock a WD ROM we need the MRT ver 3.0 programmer...The OP does not have that programmer...That's the discussion here. Not the bugs in the software..
BTW. Do you have MRT programmer ver 3.0?
Rgds
www.datasave.ro
PostPosted: June 21st, 2023, 5:22
Rgds
I have super duper Elnec programmers ,So i just remove chip ,Read ,unlock and solder again . :D
PostPosted: June 22nd, 2023, 22:18
Banned User
Rgds
Thanks I will try it. for now MRT said I can send them the files after I remove the chip from the board, read it and sent it to them they will unlock and send it back to me. I will order the programmer eventually.
