 Post subject: ST2000DM001 – Head 0 Dead, SA Backed Up, Data Access Options
PostPosted: January 21st, 2026, 4:02
I’m working on a Seagate ST2000DM001 (Grenada) with Head 0 dead. Before the failure, the drive could identify but the heads were weak, so I backed up all resources, including ROM, SA modules, and system files. After that, Head 0 failed, and now the drive does not identify / does not go ready.
Is there any way to access user data using the existing SA backup, and imaging H1, H2, H3...etc without performing a head swap?
Any advice would be appreciated.
 Post subject: Re: ST2000DM001 – Head 0 Dead, SA Backed Up, Data Access Opt
PostPosted: January 30th, 2026, 5:18
I need your guidance regarding motherboard compatibility for the MRT tool.
My system configuration is:
Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz (12 CPUs)
Please suggest which motherboard (chipset/model) is best suitable and fully compatible with MRT for stable performance.
Looking forward to your support.
