Samsung F3 Busy
http://forum.hddguru.com/viewtopic.php?f=28&t=30206
Author:  databack [ December 22nd, 2014, 12:35 ]
Post subject:  Samsung F3 Busy
This is a log file of Samsung F3 HD502HJ.
It's Busy....
How can I repair it?
Terminal.txt [1.73 KiB]
Downloaded 1281 times
Author:  MindMergepk [ December 22nd, 2014, 16:39 ]
Post subject:  Re: Samsung F3 Busy
seems some bad sector in SA,
do a hot swap, if the heads are ok it should work
Author:  mrtlabinfo [ December 22nd, 2014, 22:31 ]
Yes, it is right. You should have a try.
Author:  Amarbir[CDR-Labs] [ December 28th, 2014, 14:47 ]
It's Busy....
Hello ,
Do You Know How Samsung HDD's Work ? . You Should Try And Locate Some Manuals And Read About Samsung HDD's in General .In The Log i can clearly see there seems to be a issue in the FIT module .This Module is Used to store critical start data for SA .Without this Module its hard to know where is SA etc etc to cut it short .Both the copies on head one and zero have read issues .The people are asking you to do a hot swap .In this case you will need to copy some critical modules and write them to donor and then might be try hot swap .The first issue is how will you read those modules as the fit module is not working .I would love to see thus working with MRT .I am currently talking with them for 2 units .Lets see hope this helps .Feel free to ask any questions
PS : Its Been a While i Had Stopped Doing Data Recovery Work Might Be This info is outdated but i am trying to catchup fast :mrgreen:
