 Post subject: I need WD10EARS 00Y581 fw for MRT
PostPosted: January 4th, 2015, 15:13
Hello, everyone!
I am looking for LDR for the model above for MRT card. Does anyone have it, please? For self-test, the program tells me I need module 28. But I think the loader will do…hopefully.
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 4
Head map : .....................................: F
SA Cyl Count : .................................: 192
Serials Mark : .................................: CE16
Control version : ..............................: 63B0
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 15.3WF
ROM generation : ...............................: 15.3WF
Link table version : ...........................: 06.08
ROM Firmware version : .........................: 0015003W
 Post subject: Re: I need WD10EARS 00Y581 fw for MRT
PostPosted: January 6th, 2015, 0:01
Hi, if there are bad sectors in 28 module.
Please try to enter the program with "Normal Mode" and use "SA structure test" function to test.
You need to make the MRT to recognize the HDD first and then do the self-test and load LDR.
MRT Lab - Your data recovery, our committed solution.
http://en.mrtlab.com/
PostPosted: February 2nd, 2015, 12:53
Thank you!
cron
