 Post subject: Share the tips: Speed Up File Image
PostPosted: May 8th, 2015, 5:58
Found this resource. Share with you all here. :)
Speed Up File Image
1. Uncheck the options of "Hex data", "Copy speed", "Data scan", and go to Log.
2. Set the task parameters as below.
Note: This is a general way to speed up file image. It applies for disks which can be read after skipping errors. Users should take the situation of disk into consideration before doing this.
Hope all of us can share what we have for better DR. :D
 Post subject: Re: Share the tips: Speed Up File Image
PostPosted: May 8th, 2015, 7:15
Come On ,
Cloning a Disk With FAST Copy Option :evil:
PostPosted: May 8th, 2015, 18:07
So happy I purchased the real DE and not some clone....
PostPosted: May 9th, 2015, 7:24
Well,
Did You See My Bday Wishes :) .Happy Belated Bday .You Have DDI4 Or DDI3 ?
PostPosted: May 9th, 2015, 7:34
For the first pass I personally keep the timeouts set to around 450ms (WD) or 150ms (Seagate) as those seem to be the numbers where they rarely ever lose readiness. Then I dial it up on successive passes.
