 Post subject: MRT Pro - Disk Scaning Tool Erasing Loop Bug
PostPosted: May 7th, 2015, 4:28
Well MRT Team,
You have stopped responding to clients in HDDGURU i think .If Dimitry sir had created this "Subforum " on his own behalf then its totally fine we can understand .But if you have requested him to create a subforum then "You should be responding to our problems and bug reports " . If you run the disc scan tool in MRT Ver 2.0.4.2 and click on tests->Erase HDD Data -> Data Coverage Erase You will see that the percentage of completed thats shown down left side keeps on going 1...2..3...4...5...6...7 and then again 1...2...3...4...5 and so on .Nate a note of this bug .Proof Attached
Please See the Sector Count in Picture 1
Now see the Sector Count in Picture 2
PS : Now See The Percentage In The Bottom Left of The Software .I Found Another Bug But i Will Document it Tommorow .One Bug a Day is Enough I Think [ 30 Bugs a Month Is My Target ]
 Post subject: Re: MRT Pro - Disk Scaning Tool Erasing Loop Bug
PostPosted: May 7th, 2015, 4:59
Hi ,
Could Not Edit My Post In Place Of " Nate a note of this bug " I Meant " Take a Note Of this Bug " .
PostPosted: May 7th, 2015, 8:06
Bugs like this should have been identified during MRT's glorious years selling into China?
PostPosted: May 7th, 2015, 9:22
Guru ,
In The Last 5 Hours i Have discovered 5 Bugs Totally Nonesense Testing They Have
PostPosted: May 8th, 2015, 1:31
[quote="Amarbir"]
Thanks for your information. But it is not a bug.
This function is the erasing command of a general protocol. In the erasing process, there will report the progress of it. This protocol command is supported by hard disk of old models. For some new models, this function is not well supported.
PostPosted: May 8th, 2015, 4:29
Hello ,
I have Not understood a thing what you said .Has Anyone Else Understood Anything ? . Please Let Me Know " I Hope You Understood My Question "
