Page 1 of 1
Share the tips: Speed Up File Image
Posted: May 8th, 2015, 5:58
by hddman
Found this resource. Share with you all here. :)
Speed Up File Image
1. Uncheck the options of "Hex data", "Copy speed", "Data scan", and go to Log.
2. Set the task parameters as below.
Note: This is a general way to speed up file image. It applies for disks which can be read after skipping errors. Users should take the situation of disk into consideration before doing this.
Hope all of us can share what we have for better DR. :D
Re: Share the tips: Speed Up File Image
Posted: May 8th, 2015, 7:15
by Amarbir[CDR-Labs]
Come On ,
Cloning a Disk With FAST Copy Option :evil:
Posted: May 8th, 2015, 18:07
by thatdellguy
So happy I purchased the real DE and not some clone....
Posted: May 9th, 2015, 7:24
thatdellguy wrote:So happy I purchased the real DE and not some clone....
Well,
Did You See My Bday Wishes :) .Happy Belated Bday .You Have DDI4 Or DDI3 ?
Posted: May 9th, 2015, 7:34
by data-medics
For the first pass I personally keep the timeouts set to around 450ms (WD) or 150ms (Seagate) as those seem to be the numbers where they rarely ever lose readiness. Then I dial it up on successive passes.
