Page 1 of 1
Introduction of MRT Data Recovery Software 2.0.4.3 Version
Posted: May 21st, 2015, 23:15
by mrtpro
A new version of MRT data recovery software was released. Version number: 2.0.4.3
Download link of English version: http://us.mrtlab.com/download/
Below is an introduction of 2.0.4.3 version.
MRT Pro supports 64-bit windows operating system now. With the expansion of memory capacity, traditional 32-bit operating system can no longer support memory with greater capacity than 4GB. So it is a main trend to upgrade to 64-bit system in data recovery industry. With this hardware and software upgrade, MRT Pro can support 64-bit windows system.
MRT Lab released a new version two-port card in April, 2015. The card adopts new framework that integrates power module on one single circuit board with less interference, faster speed and greater stability. Working with MRT software of the newest version, it supports 64-bit system and multiple processes.
With support for multiple processes, users can run more than one MRT processes at the same time, with each attached to specified ATA interface. For example, users can attach the first MRT process to ATA0, attach the second to ATA1. They can run independent utility on each MRT process without interfering each other. For example, the first process use DE to copy data in ATA0, while the second process repairs hard drive in ATA1 with MRT utility. In this way, if the program crashes by mis-operation in ATA1 process, the ATA0 process will not be affected. In addition, it will be much more convenient for users’ multi-task operation with processes attached to different ATA ports. This feature is particularly useful when repairing more than one hard disks.
The new MRT hardware card supports 64-bit system and multiple processes. It is available now. MRT users can get their old cards changed to the new version. Please contact us for more details. :D
DE adds support for Persian codes and some other languages in this upgrade. Users can extract files named by various languages. WD utility can support Draco,Giant,Bigbear families now. We also add support for MQ01ABD family in Toshiba utility. Users can shield head (cut head) in Toshiba with MRT Pro. Since this upgrade, all MRT installation files contain digital signature of MRT Lab. In this way, the identity of software publisher can be confirmed so as to reduce the possibility of being blocked by anti-virus software by mistake. So the 64-bit driver of MRT new hardware card is also digitally signed to make sure that it can be loaded by system properly.
Note:
Serial number of MRT hardware card English version: SAWGXXXX, SNWGXXXX
Serial number of MRT hardware card Chinese version: SAWXXXX, SNWXXXX
Since this version, MRT hardware card English version can only work with English software. MRT hardware card Chinese version can only work with Chinese software. Otherwise, there will report "Language Error!".
Above is introduction of this upgrade. Please check upgrade log for more details.
We strive to provide better products and service for MRT users.
