| Automatic translator repair " Seagate " http://forum.hddguru.com/viewtopic.php?f=28&t=31660 |
Page 1 of 1 |
| Author: | unknown [ July 26th, 2015, 13:44 ] |
| Post subject: | Automatic translator repair " Seagate " |
Hello! Has someone tried this function before and worked " Automatic translator repair " with Seagate F3? ST3500418AS CC38 Partial sector access until ( 14000 ) sectors |
| Author: | michael chiklis [ July 29th, 2015, 10:56 ] |
| Post subject: | Re: Automatic translator repair " Seagate " |
The automatic translator repair for limited sector access fix, is not very good. HD Doctor of SalvationData is much better for this purpose. However, if you know the exact LBA where begins limited access, you could do manual repair by inserting that LBA. MRT automatic translator repair ---> not good MRT manual translator repair ------> pretty good |
| Author: | unknown [ July 29th, 2015, 11:20 ] |
Thanks a lot for reply. I will give it a try. Thank you |
| Author: | data-medics [ July 29th, 2015, 11:54 ] |
You can just do it in terminal. 1. Check for NRG by entering command: T>V40 2. Clear NRG if necessary using command: T>i4,1,22 3. Maybe Clear SMART too if you want: 1>N1 4. Regenerate Translator: T>m0,2,2,,,,,22 Unless you're actually trying to regenerate a lost P-list in which case you'll need a proper tool like PC-3000. |
| Author: | jermy [ July 29th, 2015, 11:58 ] |
non binding advice backup before regenerating translator |
| Author: | data-medics [ July 29th, 2015, 12:18 ] |
jermy wrote: non binding advice backup before regenerating translator +1 Yes, this should go without saying. First thing I ever do when I plug in a drive, so I often forget to mention it. |
| Author: | NeGrusti [ December 20th, 2015, 2:27 ] |
data-medics wrote: 2. Clear NRG if necessary using command: T>i4,1,22 T>i4,1,22 command does NOT clear NRG. I suggest you try it yourself and see |
| Author: | Amarbir[CDR-Labs] [ December 31st, 2015, 14:04 ] |
NeGrusti wrote: data-medics wrote: 2. Clear NRG if necessary using command: T>i4,1,22 T>i4,1,22 command does NOT clear NRG. I suggest you try it yourself and see Hi , This is For Glist only |
| Author: | datahdd116 [ April 18th, 2016, 14:15 ] |
I tried success thanks |
