HDD GURU FORUMS
http://forum.hddguru.com/
help fix hdd toshiba 1TB
http://forum.hddguru.com/viewtopic.php?f=28&t=33330
Page 1 of 1
Author:  datahdd116 [ April 23rd, 2016, 4:53 ]
Post subject:  help fix hdd toshiba 1TB
I have a new working toshiba.
Selected family:MQ01ABD
Model:
Load Zones : .........................:OK
Cyl Num : ............................:207055
Head Num : ...........................:4
Vendor : .............................:TOSHIBA
Model : ..............................:MQ01ABD100
Microcode : ..........................:AXFA1U9A
G-List Reading : .....................:Err
CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,​C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
help me data recovery
Author:  sandy_t [ April 23rd, 2016, 12:38 ]
Post subject:  Re: help fix hdd toshiba 1TB
If the disk hangs in "BSY", try leaving it alone for a while. Perhaps he will give the readiness and it will be possible to clear the g-list.
Or you can remove the contact between the PSB and the connector that go to the heads, turn on the power, wait until the disk will give the readiness, then give the command "sleep" and not turning off the power to re-establish contact between PSB and HDA - you will have access to SA.
Author:  datahdd116 [ April 23rd, 2016, 14:46 ]
thank you i did try but not ok
Author:  sandy_t [ April 23rd, 2016, 15:06 ]
can you give your Skype?
Author:  data-medics [ April 23rd, 2016, 21:56 ]
Umm.... I'm pretty sure if it's new and working you don't need data recovery. Just copy the data.
Author:  datahdd116 [ May 8th, 2016, 13:55 ]
I checked and the first hdd head replacing faulty data recovery success
Author:  yogk16 [ May 10th, 2016, 6:35 ]
can we recover from internal storage disk of any device?
Author:  datahdd116 [ May 10th, 2016, 16:28 ]
Spildit wrote:
Ok ...
Whatever...
Did you swap heads and you were able to recover data ?
yes thank you
http://www.phpbb.com/
