 Post subject: Need-Firmware
PostPosted: November 9th, 2016, 7:33
WD1600AAJS-00Z4A0
DCM=HHRNHT2AHN
DATE=27 NOV 2009
PCB=2060-701537-004
 Post subject: Re: Need-Firmware
PostPosted: November 9th, 2016, 9:03
firmware version ??
PostPosted: November 9th, 2016, 10:52
@ Abdul Rauf, Its 000500FA ?
PostPosted: November 9th, 2016, 11:47
i cannot read service area how to tell fw verion. hdd come to me a burn pcb i replace a pcb but can't regenerate rom.
PostPosted: November 9th, 2016, 12:23
Cannot read the ROM with n external programmer ?
PostPosted: November 9th, 2016, 15:04
main controller ic is damaged.
PostPosted: November 9th, 2016, 15:41
Assuming that the ROM is embedded in the main IC, and there's no external U12. Then you'll just need to use a close enough ROM + LDR combo from a similar drive. Once you get the LDR loaded, read tracks, extract modules, rebuild ROM, then you should be good to go. As long as the ROM and LDR match each other you should be able to read tracks. The DIR location just might be different.
PostPosted: November 9th, 2016, 16:52
He said to me he could read some tracks. But how if the PCB is burned?
ACELab partner
