| Need-Firmware http://forum.hddguru.com/viewtopic.php?f=28&t=34486 |
Page 1 of 1 |
| Author: | Abdul Rauf [ November 9th, 2016, 7:33 ] |
| Post subject: | Need-Firmware |
WD1600AAJS-00Z4A0 DCM=HHRNHT2AHN DATE=27 NOV 2009 PCB=2060-701537-004 |
| Author: | microsoftengineer [ November 9th, 2016, 9:03 ] |
| Post subject: | Re: Need-Firmware |
firmware version ?? |
| Author: | jermy [ November 9th, 2016, 10:52 ] |
@ Abdul Rauf, Its 000500FA ? |
| Author: | Abdul Rauf [ November 9th, 2016, 11:47 ] |
jermy wrote: @ Abdul Rauf, Its 000500FA ? i cannot read service area how to tell fw verion. hdd come to me a burn pcb i replace a pcb but can't regenerate rom. |
| Author: | jermy [ November 9th, 2016, 12:23 ] |
Cannot read the ROM with n external programmer ? |
| Author: | Abdul Rauf [ November 9th, 2016, 15:04 ] |
main controller ic is damaged. |
| Author: | data-medics [ November 9th, 2016, 15:41 ] |
Assuming that the ROM is embedded in the main IC, and there's no external U12. Then you'll just need to use a close enough ROM + LDR combo from a similar drive. Once you get the LDR loaded, read tracks, extract modules, rebuild ROM, then you should be good to go. As long as the ROM and LDR match each other you should be able to read tracks. The DIR location just might be different. |
| Author: | pclab [ November 9th, 2016, 16:52 ] |
He said to me he could read some tracks. But how if the PCB is burned? |
