| WD My Passport decryption bug http://forum.hddguru.com/viewtopic.php?f=28&t=35093 |
Page 1 of 1 |
| Author: | michael chiklis [ March 5th, 2017, 12:26 ] |
| Post subject: | WD My Passport decryption bug |
How to rip correctly decryption key from module 25 and load it into DE by using manual method. Auto check method often doesn't work, MRT staff should fix this bug !!! https://youtu.be/_qrs7PgStGU |
| Author: | data-medics [ March 5th, 2017, 12:58 ] |
| Post subject: | Re: WD My Passport decryption bug |
Nice video tutorial, makes it very clear. Also, makes me glad I have PC-3000 instead of MRT as it doesn't suffer from this issue. Nice work nonetheless. |
| Author: | michael chiklis [ March 5th, 2017, 13:35 ] |
Thank you |
| Author: | Amarbir[CDR-Labs] [ March 6th, 2017, 0:58 ] |
michael chiklis wrote: Thank you These fellows should wake up ,I have seen several of your posts telling this is wrong correct this and they do nothing .Its best they sponsor you for a free tour to their lab in china and you help them correct all this crap .I have 2 Units of MRT Pro "Not used Anymore " ,Since i have PC 3000 UDMA Now .Its like my friend michael banging his head of the MRT Chinese wall PS : Keep it up al always |
| Author: | microsoftengineer [ March 6th, 2017, 2:40 ] |
MRT dont support FireBird Disk............ |
| Author: | microsoftengineer [ March 6th, 2017, 2:41 ] |
i mean Firebird Decryption . FBlite Decryption work fine |
| Author: | Amarbir[CDR-Labs] [ March 6th, 2017, 3:34 ] |
microsoftengineer wrote: MRT dont support FireBird Disk............ Lol, What did Michael do Up ,Just did What You Said does Not Support ,Whats there To support More In This Now |
| Author: | ccc [ March 14th, 2017, 3:24 ] |
microsoftengineer wrote: MRT dont support FireBird Disk............ Hi I'm currently working on a case exactly like this, a Firebird disk converted to SATA, and to my surprise the utility is working as it should, no tricks need to be done...The only thing I did was not to do "Auto check" function but instead I did "Load from file" and pointed to mod 25 and that's all, the utility is decrypting the data. I don't know why in Michael case was not working...maybe he is using an older version of the software? Regards |
| Author: | michael chiklis [ March 19th, 2017, 7:37 ] |
Hi, when i created this video i was already using last mrt version (v. 161102) In some case 'auto check' works, in other doesn't, it depends from type of encryption applied by the MCU on native pcb. In my case, MCU model was JMS538S, so i had to dump manually just the key code from mod 25 (or from EDEK file) and load it into mrt utility. |
| Author: | ccc [ March 22nd, 2017, 2:34 ] |
Hi Michael That's what I'm talking about.....My case was exactly like yours, same hdd, same jmicron bridge, same family, but in your case the decryption steps was not working as it should and in mine case the decryption works ok. Strange.....Probably different version of firmware or the software is to blame. Rgds |
