| Long Delay Detect Issue in Seagate http://forum.hddguru.com/viewtopic.php?f=28&t=35325 |
Page 1 of 1 |
| Author: | arashtgi [ May 6th, 2017, 6:48 ] |
| Post subject: | Long Delay Detect Issue in Seagate |
Hello Guys, I have Seagate Barcuda 1TB . this hdd is does not detect on PC so i connected to MRT and saw its busy and not detected but after waiting for 3 min it become detectable in this situation i just want to know is there ant solution to repair the hard drive for normal work? i checked it with Logic Scan and it was very healthy on that so i want to know if there is any solution for repair hdd. |
| Author: | saroya44 [ July 23rd, 2018, 8:32 ] |
| Post subject: | Re: Long Delay Detect Issue in Seagate |
check the modules, module 35 is corrupted, re write the module from a donor. |
| Author: | data-medics [ July 23rd, 2018, 10:08 ] |
saroya44 wrote: check the modules, module 35 is corrupted, re write the module from a donor. @OP, just ignore this. You need to modify system file 93 to disable all the SMP options such as bad sector reallocation and media cache. In MRT I believe it's called, "Edit HDD ID" to get to that function (though I've never found it to work well in MRT). |
