 Post subject: sedlock offset location FBLITE family
PostPosted: June 18th, 2017, 17:21
hi guru
is anyone know where is the sedlock offset location for the WDC "WD10JMVW-11AJGS1" "FBlite family"?
 Post subject: Re: sedlock offset location FBLITE family
PostPosted: June 18th, 2017, 17:26
Analysis of Western Digital ROYL firmware MOD 02:
http://www.hddoracle.com/viewtopic.php?f=59&t=821&p=12801
PostPosted: June 18th, 2017, 17:38
dear fzabkar
thanks for your reply.and your good link to know about 02 module and using MOD2DUMP.7z for locked drive but my problem is working on a drive it was unlock sed by pc3000 and know the customer give it to me for data recovery.
and know i want put sedlock back to maybe access the data by usb pcb.
and can't found the offset because i don't have the original 02 to use MOD2DUMP.7z to see the different between the original 02 and the patched.
PostPosted: June 18th, 2017, 17:46
thanks Spildit that was nice trick.
PostPosted: June 18th, 2017, 17:50
If you had followed my instructions, you would have been able to locate the SED bit with a hex editor.
PostPosted: June 19th, 2017, 2:07
If you are familiar with Hex editor, there is a flag on a certain address.
